folding mirror DIY
txavita
Hello, when you buy the Mercedes had no electric folding mirrors and when I saw that they cast not down manually .. [Lonely.gif], then investigate the option to install the back ... after seeing that you had to change many door modules ... and see how they worked the original ... I decided that I would improve the system.
The system is very simple, using the original folding mirrors (I have only one time). Dare a circuit, these command and closed with open (tested but not completed).
Also be operated from inside the holes in locating original keypad no function.
Are independent so that Abato where needed, and the power progressively folded .. automated no touch, the mirror can be angled down to park.
[YOUTUBE]dbmXA2_NYqU[/YOUTUBE]
Have to say, greetings.
skaman
