Технические характеристики G500 2000 г.в. ( на английском)
  • Автор темы Автор темы Don300
Don300
Общие сведения.
463 GE 50
Description463.248 (station wagon)
Productionsince 03.2000 / 11.2000
Двигатель.
Combustion principlefour-stroke Otto (with manifold-injection and emission control device with 3-way catalyst)
Configurationfront, longitudinal; vertical
Engine typeM 113 E 50 / 113.962
Number of cylinders / arrangement8 / 90° V; light-alloy block
Bore x Stroke97.0 x 84.0 mm
Total displacement4966 cc
Compression ratio10.0
Crankshaft bearings5
Rated output218 kW / 296 hp at 5500 rpm
Rated torque456 Nm at 2800 - 4000 rpm
Number of valves / arrangement2 intake, 1 exhaust / V-shaped overhead
Valve operation1 overhead camshaft per cylinder bank
Camshaft drivedouble roller chain
Fuel systemmicroprocessor controlled injection system with hot-film air mass sensor (Bosch ME engine management)
Coolingwater cooling / pump; 12 l water
Lubricationpressure circulation lubrication / 8 l oil
Electric system12 V
Battery100 Ah / in the wheelhouse rear left
Generatorthree-phase AC / 2100 W
Starterelectrical / 1.7 kW
Ignitionmap-controlled phased twin-spark ignition
Fuel tank: position / capacityunder the load floor / 96 l
Fuel supplyelectric delivery pump
Кузов и подвеска.
Frame designbox-section ladder-type frame / steel unit body
Front-wheel suspensionrigid axle; 2 trailing arms, 1 wishbone (Panhard bar)
Rear-wheel suspensionrigid axle; 2 trailing arms, 1 wishbone (Panhard bar)
Front springscoil springs, supplementary rubber suspension, torsion bar stabilizer
Rear springscoil springs, supplementary rubber suspension
Shock absorber front/reartelescopic shock absorbers
Steeringrecirculating-ball power steering
Steering ratio19.1:1 / 3.8 turns lock-to-lock
Brake system (foot brake)hydraulic dual-circuit brake system with vacuum booster and antilock system, from 09.2001 with Brake Assist; disc brakes front (internally ventilated) and rear
Parking brake (hand brake)mechanical (manually operated), acting on rear wheels
Diameter of brake discs and/or brake drumsbrake discs front / rear: 315 / 272 mm
Wheelslight-alloy wheels
Wheel rims7 1/2 J x 18 H 2
Tires265/60 R 18 H
Driven wheelspermanent four-wheel drive on front and rear wheels, from 09.2001 controlled via electronic traction system ETS
Drivetrainfrom power divider via single-
Трансмиссия и динамика.
Gearing5-speed automatic transmission (electronically controlled)
Availibilityas standard
Shiftingcentral floor selector lever
Clutchhydraulic torque converter with slip-controlled lockup clutch
Transmission typeplanetary gear
Gear ratiosI: 3.59; II: 2.19; III: 1.41; IV: 1.0; V: 0.83; R: 3.16
Final drive ratiofront/rear: 4.38; transfer gear: road 0.87 / off-road 2.16
Maximum speed190 km/h (off-road 104 km/h)
Acceleration 0-100 km/h10.2 s
Commentsacceleration by shifting through from 0 - 100 km/h (2 occupants)
Fuel consumption21.8 / 13.7 / 16.7 l
by Guideline93/116/EC: figures apply to City / EUDC
Размеры и масса.
Wheelbase2850 mm
Front / rear track1475 / 1475 mm
Length4680 mm
Width1760 mm
Height1936 mm
Turning circle diameter13.26 m
Kerb weight2485 kg
Gross weight3200 kg
Gross axle weight, front1450 kg
Gross axle weight, rear1900 kg
Payload715 kg
Permissible trailer weight, braked3500 kg
Permissible trailer weight, unbraked750 kg
на сайте gclass.ru-все на русском и без гимора.Вчем проблемы? :?
Если кому надо могу предоставить информации больше чем на г-класс с фотками и описаниями. Надеюсь здесь будет все это в скором времени.
Дима, мы знаем. :))
P.s. что-то давно тебя не видно было! :)
гелик это самый джипистый джип!!!!!!!!!!!!!!!!!!!!!! :)
Добрые люди!
Подскажите, как выглядит цифра 8 в ВИН коде?
У меня, какой-то подозрительный завиток обнаружился, в верхнем кругляшке. Так и должно быть?
Очень переживаю...
Да не должно быть по идее никаких лишних завитков. А ты пробей просто VIN по опциям и номерам двигателя и коробки.
Если совпадают с фактом, забей на него да и всё.
j.bond.007
