Технические характеристики ML 320. (на английском языке)
Don300
[attachment=1:qg4a0qns]ML320.JPG[/attachment:qg4a0qns]
[attachment=0:qg4a0qns]ML_2.JPG[/attachment:qg4a0qns]
Дата производства .
Model W 163 E 32
Description 163.154
Production 05.1997 / 07.1997 - 07.2001
Двигатель.
Combustion principlefour-stroke Otto (with manifold-injection and emission control device with 3-way catalyst)
Configurationfront, longitudinal; vertical
Engine typeM 112 E 32 / 112.942
Number of cylinders / arrangement6 / 90° V; light-alloy block
Bore x Stroke89.9 x 84.0 mm
Total displacement3199 cc
Compression ratio10.0
Crankshaft bearings4
Rated output160 kW / 218 hp at 5700 rpm
Rated torque310 Nm at 3000 - 5000 rpm
Number of valves / arrangement2 intake, 1 exhaust / V-shaped overhead
Valve operation1 overhead camshaft per cylinder bank
Camshaft drivedouble roller chain
Fuel systemmicroprocessor controlled injection system with hot-film air mass sensor (Bosch ME engine management)
Coolingwater cooling / pump; 12.0 l water
Lubricationpressure circulation lubrication / 7.0 l oil
Electric system12 V
Battery100 Ah / in the engine compartment
Generatorthree-phase AC / 1610 W
Starterelectrical / 1.7 kW
Ignitionmap-controlled phased twin-spark ignition
Fuel tank: position / capacityin front of the rear axle / 72 l
Fuel supplyelectric delivery pump
Подвеска и колесная база.
Frame designbox-section ladder-type frame / steel unit body
Front-wheel suspensiondouble wishbone
Rear-wheel suspensiondouble wishbone
Front springstorsion bar springs, torsion bar stabilizer
Rear springscoil springs, torsion bar stabilizer
Shock absorber front/reartwin-tube gas-pressure shock absorbers
Steeringrack-and-pinion power steering
Steering ratio3.6 turns lock-to-lock
Brake system (foot brake)hydraulic dual-circuit brake system with vacuum booster and antilock system, from 09.1998 with Brake Assist; disc brakes front (internally ventilated) and rear
Parking brake (hand brake)mechanical (foot-operated), acting on rear wheels
Diameter of brake discs and/or brake drumsbrake discs front / rear: 301 / 285 mm
Wheelslight-alloy wheels
Wheel rims6 1/2 J x 16 H 2
Tires225/75 R 16 104 T; from 02.1999: 225/75 R 16 104 H
Driven wheelspermanent four-wheel drive on front and rear wheels, controlled via electronic traction system ETS
Drivetrainfrom power divider via single-piece cardan shafts on front-axle differential and rear-axle differential (power distribution 48% front, 52% rear)
Трансмиссия и динамические характеристики.
Gearing5-speed automatic transmission (electronically controlled)
Availibilityas standard
Shiftingcentral floor selector lever
Clutchhydraulic torque converter with slip-controlled lockup clutch
Transmission typeplanetary gear
Gear ratiosI: 3.93; II: 2.41; III: 1.49; IV: 1.0; V: 0.83; R: 3.10
Final drive ratiofront/rear: 3.69; transfer gear: road 1.0 / off-road 2.64
Maximum speed180 km/h (controlled); from 02.1999: 195 km/h
Acceleration 0-100 km/h9.5 s
Commentsacceleration by shifting through from 0 - 100 km/h (2 occupants)
Fuel consumption18.2 / 11.2 / 13.8 l
by Guideline93/116/EC: figures apply to City
Масса и размеры.
Wheelbase2820 mm
Front / rear track1565 / 1565 mm
Length4587 mm
Width1833 mm
Height1807 mm
Turning circle diameter11.90 m
Kerb weight1990 kg; from 09.1998: 2010 kg; since .1999: 2120 kg
by GuidelineEC 92/21 (including driver, 68 kg, and baggage, 7 kg; tank 90 % full)
Gross weight2650 kg; since .1999: 2750 kg
Gross axle weight, front1250 kg; since .1999: 1300 kg
Gross axle weight, rear1600 kg
Payload660 kg; from 09.1998: 640 kg; since .1999: 630 kg
Permissible trailer weight, braked2650 kg; since .1999: 3500 kg
Permissible trailer weight, unbraked750 kg
    28,1 КБ · Просмотры: 590
    55,7 КБ · Просмотры: 561
alexxeno
ML430 W163 USA
Добрый день,уважаемый Damon!Я дико извиняюсь,что тревожу!Я новенький и не знаю в какую тему это писать.Я четыре месяца назад,купил классный МЛ430 2000года американецW163.Всем доволен,как слон,но нигде не могу найти navi CDилиDVD для RA 4910 Alpine.Я не знаю вообще какое CD.Не будете ли так добры,чем нибудь помочь,какую-нибудь ссылочку или фотку.Буду очень признателен.С уважением Руслан.
Fulcrum
