Технические характеристики SLK 230K W170 ( на английском)
Don300
[attachment=1:3r9sm9j9]slk.JPG[/attachment:3r9sm9j9]
[attachment=0:3r9sm9j9]slk_2.JPG[/attachment:3r9sm9j9]
Общие данные.
ModelR 170 E 23 ML
Description170.447
Production10.1995 / 07.1996 - 02.2000
Двигатель.
Combustion principlefour-stroke Otto (with manifold-injection and supercharger with charge-air cooling; emission control device with 3-way catalyst)
Configurationfront, longitudinal; vertical
Engine typeM 111 E 23 ML / 111.973
Number of cylinders / arrangement4 / in line; 15° inclination to the right
Bore x Stroke90.9 x 88.4 mm
Total displacement2295 cc
Compression ratio8.8
Crankshaft bearings5
Rated output142 kW / 193 hp at 5300 rpm
Rated torque280 Nm at 2500 - 4800 rpm
Number of valves / arrangement2 intake, 2 exhaust / V-shaped overhead
Valve operation2 overhead camshafts (intake camshaft adjustable)
Camshaft drivedouble roller chain
Fuel systemmicroprocessor-controlled injection system with HFM (Bosch ME engine management) / supercharger with charge-air cooling
Coolingwater cooling / pump; 8 l water
Lubricationpressure circulation lubrication / 5.5 l oil
Electric system12 V
Battery46 Ah / in the engine compartment
Generatorthree-phase AC / 1260 W
Starterelectrical / 1.4 kW
Ignitionmap-controlled ignition
Fuel tank: position / capacityabove the rear axle / 53 l
Fuel supplyelectric delivery pump\
Подвеска и колеса.
Frame designsteel unit body
Front-wheel suspensiondouble wishbone
Rear-wheel suspensionmultilink suspension
Front springscoil springs, torsion bar stabilizer
Rear springscoil springs
Shock absorber front/reargas-pressure shock absorbers
Steeringrecirculating-ball power steering
Steering ratio15.5:1 / 3.11 turns lock-to-lock
Brake system (foot brake)hydraulic dual-circuit brake system with vacuum booster and antilock system, from 06.1997 with Brake Assist; disc brakes front (internally ventilated) and rear
Parking brake (hand brake)mechanical (manually operated), acting on rear wheels
Diameter of brake discs and/or brake drumsbrake discs front / rear: 288 / 278 mm
Wheelslight-alloy wheels
Wheel rimsfront: 7 J x 16 H 2; rear: 8 J x 16 H 2
Tiresfront: 205/55 R 16 91 V; rear: 225/50 R 16 91 V
Driven wheelsrear wheels
Drivetraindivided cardan shaft
Трансмиссия и динамика.
5 скоростная ручная КПП.
Gearing5-speed manual transmission
Availibilityas standard
Shiftingcentral floor gear shift lever
Clutchdry single-disc clutch
Transmission typechange-speed gear
Syncromesh gearsI - V
Gear ratiosI: 3.86; II: 2.18; III: 1.38; IV: 1.0; V: 0.80; R: 4.22
Final drive ratio3.46
Maximum speed231 km/h
Acceleration 0-100 km/h7.4 s
Commentsacceleration by shifting through from 0 - 100 km/h (2 occupants)
Fuel consumption13.3 / 7.0 / 9.3 l
by Guideline93/116/EC: figures apply to City / EUDC (extra-urban) / NEDC (New European Driving Cycle, average from 36,8% City and 63,2% EUDC)
5 скоростная АКПП
Gearing5-speed automatic transmission (electronically controlled)
Availibilityoptional
Shiftingcentral floor selector lever
Clutchhydraulic torque converter with slip-controlled lockup clutch
Transmission typeplanetary gear
Gear ratiosI: 3.93; II: 2.41; III: 1.49; IV: 1.0; V: 0.83; R: 3.10
Final drive ratio3.27
Maximum speed227 km/h
Acceleration 0-100 km/h7.3 s
Fuel consumption13.6 / 7.0 / 9.5 l
Размеры и масса.
Wheelbase2400 mm
Front / rear track1488 / 1485 mm
Length3995 mm
Width1715 mm
Height1284 mm
Turning circle diameter10.58 m
Kerb weight1325 kg
by GuidelineEC 92/21 (including driver, 68 kg, and baggage, 7 kg; tank 90 % full)
Gross weight1585 kg
Gross axle weight, front785 kg
Gross axle weight, rear800 kg
Payload260 kg
    55,1 КБ · Просмотры: 544
    49,4 КБ · Просмотры: 513
monza
