Инструкция по раскодировке команда (англ. язык)
Don300
The following cars are able to be unlocked with this manual:
CLS - W219 E CLASS - W211 SLK - R171 S CLASS W220 (WIDESCREEN) SL R230 (WIDESCREEN)
This guide will allow you to enable the following features
View the TV while the car is moving
Play multi-regional disks and DVDRW
Enable mp3 playback
Modify other hidden features
Note: Please follow this guide carefully and you will be able to open these features within minutes. We hold no responsibility for human error these codes work for the right console listed above. We also like to point out that it is illegal to enable the TV whilst the car is in motion and therefore advice you not to activate this feature. If you go ahead then it’s your responsibility.
Copyright © 2006 Stuart Criddle All Rights Reserved.
This work is registered with the UK Copyright Service: Reg. No:255604
INSRUCTIONS
1 Press the audio button to enter audio mode
2 To enter the engineering mode press the 1 mute, 2 phone and
3 serv buttons and hold for apx 45 seconds until you see a message saying “welcome to engineering mode”.
To enter the secret menu press and hold * button then the # followed by the < button and hold them all simultaneously.
To access the video in motion menu press the button next to Dr.Dist.
Using the arrow keys deactivate all of settings with the OK button. Your screen should now look like the photo below –
Press the back button to go back to the main menu
7
To access the MP3 enabling menu press the button next to Backd.
Using the arrow keys, highlight the MP3 feature and enable it using the OK button.
Now go back to the main menu using the back button.
8
To access the DVD region menu, press the button next to regcod.
Using the arrow keys, highlight the region free setting and enable it using the ok button.
To activate the settings press back then end and switch the command console off then back on again.
All setting may be activated and de-activated as many times as you want.
CANTER
W211 E220 CDI 170HP
PRIVET, NE PULUCEAETSA VOITI V engineering mode,
OBIESNI POJALUISTA 1, 2 PUNKT ESLI MOJES
SPOSIBO!!!
alexleus
