Короче сам спросил сам отеил:
Отзывные компании по ML( но нет увереннсоти что это все, да и 100% тоже нет):
[FONT="]Recall:[/FONT]
[FONT="]No. 1 of 7[/FONT][FONT="][/FONT]
[FONT="]Recall Ref:[/FONT]
[FONT="]R/2012/091[/FONT]
[FONT="]Exact Model:[/FONT]
[FONT="]M Class[/FONT]
[FONT="]Description:[/FONT]
[FONT="]FLOOR MAT MAY IMPEDE ACCELERATOR PEDAL[/FONT]
[FONT="]WDC1660042A039654 to WDC1660242A099743[/FONT]
[FONT="]Build Date:[/FONT]
[FONT="]01 January 2011 to 31 December 2011[/FONT]
[FONT="]Numbers:[/FONT]
[FONT="]2540[/FONT]
[FONT="]Defect:[/FONT]
[FONT="]It has been established that if the vehicle is fitted with all weather or ribbed floor mats the accelerator/throttle pedal may contact the floor mat. Although this will just be a temporary contact, this could delay the accelerator/throttle pedal releasing.[/FONT]
[FONT="]Action:[/FONT]
[FONT="]Recall affected vehicles and check if the vehicle is fitted with all weather/ribbed floor mats. [/FONT][FONT="]If fitted remove from the vehicle.[/FONT]
[FONT="]Launch Date:[/FONT]
[FONT="]29 November 2012[/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]No. 2 of 7[/FONT][FONT="][/FONT]
[FONT="]R/2008/149 [/FONT]
[FONT="]M, C, CLK, E, CLS, S, R & G- CLASSES[/FONT]
[FONT="]ENGINE COULD LOSE POWER. [/FONT]
[FONT="]1/1/06 to 31 Dec 07[/FONT]
[FONT="]19331[/FONT]
[FONT="]The electrical connection in the interior of the crankshaft sensor's chip housing may be interrupted, which may result in loss of power and the inability to restart engine [/FONT]
[FONT="]Recall affected vehicles and replace crankshaft sensor [/FONT]
[FONT="]17 November 2008[/FONT]
[FONT="] [/FONT]
crankshaft position sensor - датчик угла поворота коленчатого вала
[FONT="] [/FONT]
[FONT="]No. 3 of 7[/FONT][FONT="][/FONT]
[FONT="]R/2008/147 [/FONT]
[FONT="]M-CLASS, SLK-CLASS, CLK-CLASS, E-CLASS, C-CLASS, R-CLASS & A-CLASS[/FONT]
[FONT="]ENGINE EMERGENCY SHUT OFF, ON BOARD DIAGNOSIS OR TANK/SPEEDO SIGNAL MAY BE AFFECTED [/FONT]
[FONT="]1/1/04 to 10/8/08[/FONT]
[FONT="]72[/FONT]
[FONT="]Possibility of transfer of incorrect control unit software which could affect engine shut off control in an emergency situation or the on board diagnosis system or tank/speedometer signal [/FONT]
[FONT="]Recall affected vehicles and replace SAM control unit [/FONT]
[FONT="]10 November 2008[/FONT]
[FONT="]No. 4 of 7[/FONT][FONT="][/FONT]
[FONT="]R/2011/131[/FONT]
[FONT="]ML[/FONT]
[FONT="]CRUISE CONTROL MAY FAIL TO DEACTIVATE[/FONT]
[FONT="]WDC1631131A256307 to WDC1631752A371862 and 4JG1631541A166603 to 4JG1631751A336847[/FONT]
[FONT="]20419[/FONT]
[FONT="]It has been identified that a fault in the brake light switch may, in very rare cases, cause the cruise control to not deactivate when the brake is applied.[/FONT]
[FONT="]Recall the affected vehicles and replace the brake switch.[/FONT]
[FONT="]31 October 2011[/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]No. 5 of 7[/FONT][FONT="][/FONT]
[FONT="]R/2010/205[/FONT]
[FONT="]ML, C, E, S and R class[/FONT]
[FONT="]FUEL MAY LEAK[/FONT]
[FONT="]WDC1641211A626833 to WDD2183232A000277[/FONT]
[FONT="]2972[/FONT]
[FONT="]Fuel may leak from the fuel filter housing onto the road surface and thereby make the road slippery for road users.[/FONT]
[FONT="]Recall the vehicles that are likely to be affected to replace the fuel filter housing, if it is leaking.[/FONT]
[FONT="]07 January 2011[/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]No. 6 of 7[/FONT][FONT="][/FONT]
[FONT="]R1999/106[/FONT]
[FONT="]SEAT BELT MAY DISENGAGE[/FONT]
[FONT="]TO BE ADVISED[/FONT]
[FONT="]To be advised[/FONT]
[FONT="]3839[/FONT]
[FONT="]There is a possibility that the seat belt at the drivers seat may disengage because the buckle cap may not properly lock in position.[/FONT]
[FONT="]Recall affected vehicles and replace seat belt with a modified version.[/FONT]
[FONT="]04 February 2000[/FONT]
[FONT="]No. 7 of 7[/FONT][FONT="][/FONT]
[FONT="]R/2003/060[/FONT]
[FONT="]Possible loss of power assisted steering fluid[/FONT]
[FONT="]25000[/FONT]
[FONT="]An oversize hose clamp may allow a gradual loss of Power Assisted Steering Fluid over a period of time[/FONT]
[FONT="]Recall affected vehicle and replace hose clamp with modified type[/FONT]
[FONT="]12 August 2003[/FONT]
[FONT="]No. 1 of 1[/FONT][FONT="][/FONT]
[FONT="]R/2009/031[/FONT]
[FONT="]ML CLASS[/FONT]
[FONT="]AUTOMATIC LIFTGATE MAY OPEN INADVERTENTLY[/FONT]
[FONT="]01 July 2008 to 31 Mar 2009[/FONT]
[FONT="]2685[/FONT]
[FONT="]Automatic liftgate may open inadvertently due to moisture entry into the control unit from water leaks in the area of the rear lamps.[/FONT]
[FONT="]Recall the vehicles that are likely to be affected to reposition the control unit and replace the seals of the right and left rear lamp units.[/FONT]
[FONT="]29 May 2009[/FONT]
