Уточняем дату выпуска, номер двигателя и комплектацию по VIN (старая тема)
Статус
AleX-Trail
GLK 220
Добрый день.
Вот номерок:
WDB9340321L590940
Спасибо!
A57 Front axle offset
AD0 Axle ratio i = 2.846 (HL6)
AL3 Front axle 7.5 t
AM9 Rear axle H6, 13.0 t, crown wheel 440
B65 Compressed air dryer, heated
B69 Air reservoir, aluminium
BA1 Voith retarder, performance optimised
BB5 Disc brakes on front and rear axle
BB7 Telligent stability control
BB8 Telligent braking system with ABS and ASR
BC2 E-APU, electronic air processing unit
BC6 Active Brake Assist 2
BD6 Brake and elec.connections,low,for semitr. tractor
C73 Front underride guard (EC)
CB8 Side skirts, aerodynamic
CB9 Splash guard (EC), front
CL9 Steering LS 6/LS 8
CW3 Deletion, integral rear
DS3 Pop-up roof, electric
E39 Automatic cutouts
E52 CB radio system
E86 Battery sensor
EB3 Batteries, 2 x 12V/220 Ah, low-maintenance
EC6 Trailer socket, 15-pin
ED9 Provision for fitting electrical devices
ES8 Additional socket, 24 V/15 A, firewall
ET1 Voltage transformer, 24 V/12 V, 8 A
ET5 Telligent proximity control
ET7 Telligent Lane Assistant
EU2 CD-Radio Bluetooth, without mobile phone charging interface
EV0 Communications interface (KOM)
EV2 Provision for fitting CB radio
EV5 Provision for fitting telephone, fax
EX3 Provision for fitting FleetBoard
EX8 Pre-installation for toll tracing, distance-based,material provided by
F04 L-cab
F33 Air deflectors, adjustable
F52 Sun visor, exterior, transparent
FA5 Curtain, along side of bed/bunk(s)
FC7 Windows, tinted, without sun filter
FE5 Power windows for driver's/co-driver's door
FG1 Digital clock with alarm function
FG6 Drawer above engine tunnel, pull-out
FH0 Cab interior trim, brushed steel
FH5 Carpet, engine tunnel
FJ4 Floor mat, rubber, driver's and co-driver's side
FK0 Stowage compartments, top, with hinged lid
FL4 Comfort cab mountings, steel-sprung
FN2 Comfort cockpit
FQ2 Refrigerator box, 25 l, in drawer, pull-out
FS2 Wide-angle mirror on driver's side, heated
FS4 Sunblind, side window in driver's door
FX7 Front mirror, aerodynamic
FZ7 Immobiliser, with transponder
GE7 Mercedes PowerShift 2
GH2 Mercedes PowerShift G 211-12/14.93-1.0
GZ7 Clutch supplier F&S
H01 Auxiliary air conditioning, thermostat-controlled
H03 Air conditioning system
H61 Auxiliary hot air heater, Webasto Air Top 2000
HF2 Pollen filter
I73 Tyres, tubeless, size 315/80 R 22.5, rear axle
I76 Tyre size 385/65 R 22.5,front/leading/trail.axle
IA0 Wheel arrangement 4x2
IC4 Semitrailer tractor
ID2 Air suspension, rear axle
IF2 Model series MPII
IF6 Actros series, production location Wörth
IL1 Domestic (Germany)
IL8 Left-hand-drive version
IQ1 Wheelbase 3600 mm
IV0 18.0-tonner
IX6 V6 engines
J76 Air horns, cab roof
JD3 Tachograph, dig. EC, rpm+additional recorder, ADR
JK2 Instrument cluster, graphics-capable display
JZ1 Tachograph manufacturer VDO
K40 Tank-cap lock
KD6 Emissions monitoring for nitrogen oxide (NOx)
KE9 On-Board Diagnosis 2, with NOx check
KG2 Silencer, SCR cat. conv., medium, stainless steel
KH8 Exhaust silencer, tailpipe downwards
KP3 AdBlue tank, 85 l
KP9 AdBlue tank, plastic
KU4 Main tank, 400 l, aluminium
L16 Fog lamps, halogen
L28 Floodlights
M62 Air intake, rear at top, air cleaner below cab
MD4 Speed limiter, 90 km/h, EC
MD9 Cruise control
MO1 Viscous coupling, electromagnetic, for fan, Behr
MS5 BlueTec 5 (Euro V)
MV4 Engine, V6, LA, 320 kW (435 hp), 1800 rpm
MZ2 Coolant pump with solenoid clutch
MZ7 Air compressor, 1-cylinder, regulated
P00 Economy Pack Basic
P27 Safety Pack Top
P33 Mudguard, 3-piece, with EC splash guard
P81 Rear wing, 2550 mm vehicle width
QB7 5th-wheel coupling, Jost JSK 37, H=150 mm, manually lubricated
QC4 Front spring, 7.5 t
QM2 Mounting plate, 40 mm, for 20t 5th-wheel coupling
QM7 Fifth wheel exterior angle, with hole pattern
R04 Wheel nut cap
R60 Spare wheel carrier, provisional
R87 Spare wheel/spare wheel rim
RL7 Light-alloy wheels, 9.00x22.5, diamond-cut, Alcoa
RL8 L-alloy wheels,11.75x22.5,f.axle,diamond-cut,Alcoa
RM8 Tyre make, specially requested, Michelin
SA5 Airbag, driver
SF1 Fold-up seat, velour, co-driver
SH1 Driver's comfort suspension seat, Grammer
SM6 Comfort bed, top, w. level adjustment, with bottombed
SV6 Seat backrest, release mechanism
TL7 Weight variant 18.0 t (7.5/11.5)
X30 Registration certificate, Part II (letter)
X33 Test booklet
X57 Noise reduction measures, EC 96/20
XK0 Mercedes-Benz OnRoadService
XK4 Powertrain warranty,Gen.Terms/Con.,3 yrs/450000 km
XV6 Actros 3
Y10 First aid kit
Y27 1 wheel chock
Y29 Bracket, for wheel chock, on rubber mudguard
Y34 Tyre inflating hose, 10 m
Y44 Hazard warning triangle
Y45 Warning lamp
Y82 Front apron
YM1 FleetBoard vehicle computer
ZA6 FleetBoard components
ZC0 Steering, ZF8098
ZH1 CharterWay, min. spec. for semitrailer tractors
ZX1 Control unit, Common Powertrain Control (CPC)
ZX2 Braking system, EPB II
ZX3 Wiring harness, digital tachograph for telematics CAN
ZZ3 Vehicle, for right-side traffic
  • WDB9340321L590940.pdf
    39,2 КБ · Просмотры: 57
Это все конечно понятно :D
Я хотел бы расшифровать его... просто не дописал до конца :)
Как на первом свидании...
Все какие-то намеки и недоговоренности:
2. Если ты чего-то хочешь - говори прямо. Расставим точки над i: Полупрозрачные намеки не работают! Прозрачные намеки не работают! Даже суперпрозрачные намеки не работают! Просто скажи прямо!
Смотри выше - Alex-Trail уже все расшифровал.
rupesku
Извините. Больше не повторится.
В следующий раз, сделаем все как полагается. :)
yugmano
Уважаемые,пожалуйста, помогите узнать полную комплектацию этой машины vin: WDB1241331B237876 !
Пожалуйста помогите узнать полную комплектацию этой машины vin: WDB1241331B237876 !
ПОЖАЛУЙСТА WDB1241331B237876 !
Олег2010
C празниками Вас !
расшифруйте пожайлуста комплектацию
WDB1400421A396886
rupesku
Здравствуйте.
Расшифруйте пожалуйста данный номерок:
WDB9540321K738373
Огромное спасибо и с прошедшими праздниками.
  • WDB9540321K738373.pdf
    61,1 КБ · Просмотры: 71
SergeyKz
Добрый день,
очень нужна информация по опциям и году выпуска,
если возможно то желательно на немецком.
VIN: WDB1290631F106388
Зарание благодарен.
Добрый день,
Зарание благодарен.
WDB1290631F106388
SA-Codes:
271A (keine Benennung vorhanden)
281 AMG-PERFORMANCE LENKRAD
441 Lenksäule elektr. einstellbar
538 Antenne autom. m. Frontlautspr. o. Radio
565 Fondsitze Stoff
581 Klimatisierungsautomatik
592 WD-GRUENES GLAS RUNDUM, HEIZBARE HECKSCHEIBE-VSG
600 Scheinwerferreinigungsanlage
652 LEICHTMETALLRAEDER 8-LOCH
740 Verdeckstoff schwarz
744 Verdeckstoff dunkelblau
866 Technische Änderungen
873 Sitzheizung Vordersitze
  • WDB1290631F106388.pdf
    40,7 КБ · Просмотры: 287
Статус
Flight crew
