Крымчанин
- Сообщения
- 6.940
- Реакции
- 682
- Авто
- Дизельный Два
- Город
- ремонт любого авто с названием MERCEDES
С поиска нормальной диагностикиДобрый день.
Считали ошибки:
ME - Motor/Engine Electronics (HW: 75->003 446 88 40 , 90):
- : Fault: System Too Rich Bank 1 signal amplitude > maximum
- Code: 017222
- : Fault: Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance signal plausibility failure / Fault: The intake manifold pressure
- Code: 010664
- : Fault: ECM/PCM Internal Engine Off Timer Performance / Fault: The engine off time has an implausible value. / Fault: The Motorabstellzeit has an i
- Code: 261000
ESP - Electronic stability program (HW: 76->204 545 38 32 , 14):
- : Fault: Component ''Y10/1 (Power steering pump quantity control valve)'' has a short circuit. Component 'Y10/1 (Power steering pump quantity cont
- Code: 00C198B
- : Fault: There is an internal fault in control unit ''N30/4 (Electronic Stability Program control unit)''. There is an internal fault in control unit 'N30/4 (El
- Code: 00C1001
- : Fault: There is an internal fault in control unit 'N30/6 (Regenerative braking system control unit)'. / Fault: Control unit N47-5 (ESP control unit), int
- Code: 00C1945
С чего начать?
