Помогите!!
JaredS
Подскажите, где в интернете можно найти подробное описание ( характеристики, рисунки, чертежи ) автомобиля Mercedes A 160, 1998 г.в., 1.6 л. бензин... Очень надо... Пожалуйста... :?: :?: :?:
Don300
Вот что есть на английском.
[attachment=1:3kzr074a]A160_1.JPG[/attachment:3kzr074a]
[attachment=0:3kzr074a]A160_2.JPG[/attachment:3kzr074a]
Двигатель.
Combustion principlefour-stroke Otto (with manifold-injection and emission control device with 3-way catalyst)
Configurationfront, transverse; horizontal
Engine typeM 166 E 16 / 166.960
Number of cylinders / arrangement4 / in line; 59° inclination to the front; light-alloy block
Bore x Stroke80.0 x 79.5 mm
Total displacement1598 cc
Compression ratio11.0
Crankshaft bearings5
Rated output75 kW / 102 hp at 5250 rpm
Rated torque150 Nm at 4000 rpm
Number of valves / arrangement1 intake, 1 exhaust / V-shaped overhead
Valve operation1 overhead camshaft
Camshaft drivesingle roller chain
Fuel systemmicroprocessor-controlled injection system with hot-film air-mass sensor (HFM)
Coolingwater cooling / pump; 4.9 l water
Lubricationpressure circulation lubrication / 4.5 l oil
Electric system12 V
Battery46 Ah (with automatic transmission: 62 Ah) / under the passenger compartment
Generatorthree-phase AC / 1260 W
Starterelectrical / 0.9 kW
Ignitionmap-controlled ignition
Fuel tank: position / capacityin front of the rear axle / 54 l
Fuel supplyelectric delivery pump
Подвеска
Frame designsteel unit body
Front-wheel suspensionA-arm / McPherson strut
Rear-wheel suspensiontrailing-arm axle
Front springscoil springs, torsion bar stabilizer
Rear springscoil springs, torsion bar stabilizer
Shock absorber front/reartwin-tube / single-tube gas-pressure shock absorbers
Steeringrack-and-pinion power steering
Steering ratio19.8:1 / 3.5 turns lock-to-lock
Brake system (foot brake)hydraulic dual-circuit brake system with vacuum booster and antilock system, from 02.1998 with Brake Assist; front disc brakes (internally ventilated) and rear drum brakes
Parking brake (hand brake)mechanical (manually operated), acting on rear wheels
Diameter of brake discs and/or brake drumsbrake discs front 260 mm; brake drums rear 180 mm
Wheelssheet-steel wheels (light-alloy wheels optional)
Wheel rims5 1/2 J x 15 H 2; for sports suspension until 11.1997: 5 1/2 J x 16 H 2
Tires175/65 R 15 (for sports susp.: 195/50 R 16); from 02.1998: 195/50 R 15
Driven wheelsfront wheels
Drivetrainfinal-drive assembly and differential in unit with transmission
Трансмисия
5 -скоросктная КПП
Gearing5-speed manual transmission
Availibilityas standard
Shiftingcentral floor gear shift lever
Clutchdry single-disc clutch (automatic clutch control optional)
Transmission typechange-speed gear
Syncromesh gearsI - V
Gear ratiosI: 3.27; II: 1.92; III: 1.26; IV: 0.88; V: 0.70; R: 3.29
Final drive ratio4.06
Maximum speed182 km/h
Acceleration 0-100 km/h10.8 s
Commentsacceleration by shifting through from 0 - 100 km/h (2 occupants)
Fuel consumption9.9 / 5.7 / 7.2 l
by Guideline93/116/EC: figures apply to City / EUDC (extra-urban) / NEDC (New European Driving Cycle, average from 36,8% City and 63,2% EUDC)
5-скоростния АКПП
Gearing5-speed automatic transmission (electronically controlled)
Availibilityoptional (from 07.1998)
Shiftingcentral floor selector lever
Clutchhydraulic torque converter with slip-controlled lockup clutch
Transmission typeplanetary gear
Gear ratiosI: 3.63; II: 2.09; III: 1.31; IV: 0.90; V: 0.72; R: 3.67
Final drive ratio3.76
Maximum speed180 km/h
Acceleration 0-100 km/h11.9 s
Fuel consumption10.4 / 6.1 / 7.7 l
Размеры и вес.
2423 mm
Front / rear track1502 / 1440 mm; from 02.1998: 1503 / 1452 mm
Length3575 mm
Width1719 mm
Height1601 mm ("Avantgarde": 1581 mm); from 02.1998: 1575 mm
Turning circle diameter10.60 m; from 02.1998: 10.70 m
Kerb weight1095 kg; from 02.1998: 1115 kg
by GuidelineEC 92/21 (including driver, 68 kg, and baggage, 7 kg; tank 90 % full)
Gross weight1480 kg; from 02.1998: 1500 kg
Gross axle weight, front735 kg; from 02.1998: 745 kg
Gross axle weight, rear745 kg; from 02.1998: 755 kg
Payload385 kg
Permissible trailer weight, braked800 kg
Permissible trailer weight, unbraked400 kg
    62,8 КБ · Просмотры: 442
    61,7 КБ · Просмотры: 468
упырёк
Лично я в нете не нашёл,в Питере адрес,где можно книгу купить:Книжная ярмарка на пр.Обуховской Обороны
mioneis
Я книгу заказывала в интернете. Её я думаю могут и в Питер доставить почтой. Было это год назад поэтому уже не помню сайт где заказывала. Поищи в поисковых, думаю обязательно найдешь. Стоила гдето 300-400 р.
-=sab=-
w211 e320 4matic
тяжелая. начальник.
Вообще-то у нас на Лиговке 33 есть магазин "Транспортная книга". Ну и книжная ярмарка, думаю тоже место, где это есть.
Хотелось бы конкретизировать, что конкретно интересует в книгах? Ибо содержимое у них очень разное. Точнее - для каких целей?
Вот еще адреса:
ТРАНСПОРТНАЯ КНИГА АЛФАМЕР ПАБЛИШИНГ [20148 -7439]
193036, Санкт-Петербург г., Лиговский просп., д. 33
т. (812) 275 3327
ТРАНСПОРТНАЯ КНИГА МАГАЗИН [19859 -8058]
191040, Санкт-Петербург г., Пушкинская ул., д. 20
т. (812) 164 9807
ТРАНСПОРТНАЯ КНИГА ФИЛИАЛ [20342 -7740]
193036, Санкт-Петербург г., Невский просп., д. 91
т. (812) 279 4385
p.s. Через интернет, естественно, тоже можно заказать много где.
A140SPb
Подскажите!
Где поменять выжимной подшипник корзины сцепления? В какую цену это может обойтись?
Нужен совет… Буду очень признателен! ;)
MaRsHeL
Привет все Уменя Ашка 160 полу автомат ,проблема вот в чем ,в обшем когда купили коробка через какоето время начела видовать ошибкы ФФФФ...пошли к диагностику на Ланче чтото проделали ,после етого машина заводится но нетрогается так как не опредиляет нитралку 1-2-3-4-5 скорость видна а нетралка не определяеться в чем может быть проблема зарание спосибо ....
Lapets
