Folding Key Car Alarm & Immobiliser central lock System AL60BP
Full-feature car alarm remote control system! This is an advanced alarm system that adds remote central locking to vehicles with manual central locking. Features include total closure, car finder and an auxiliary output operated from the remote controls - ideal for use with boot releases and remote starters etc.
The built in total closure central locking interface allows the alarm to be connected to the vehicles existing central locking (where fitted) enabling the doors to be locked and unlocked (and electric windows/sunroof closed if vehicle has total closure) as the alarm is armed and disarmed. This comes complete with a very loud six tone electronic siren, adjustable shock sensor, 4 Channel Code Learning Programmable Receiver and offers many optional security and convenience features.
* Learning code remote controls - You can add or replace existing remotes with this intelligent learning code system.
* We only guarantee our remotes transmitters to work with this system
Latest Model: New Design - added (EXTRA) features/functions:
* 4 Channel Code Learning Programmable Receiver
* Learning switch: Code learning to add or programme new remotes or replace existing ones (maximum 4 remotes can be programmed-learned)
* Pneumatic lock/electric lock, positive/Negative trunk, Windows rise, auto-alarm, flash - All jumper setting
* Windows rollup Output Function:
* boot (trunk) release
* Pneumatic lock/electric lock - All jumper setting
* Many (TOP QUALITY) different remotes transmitters to choose from!!! - please see our eBay shop for complete range!
* Random Coded (Military grade - anti scan/grabber) remote controls
Super Code Protection - Copy-proof with 4.3 billion possible codes (Random code generated)
* And much more!! Plus all the standard features/functions: SEE below
Main Features:
* Remote In arm / disarm
* Silent in arm
* Trigger memory
* central door lock automatically
* car finding
* engine cut off
* LED indicator status
* Anti-hijacking
* Remote trunk open
* Output window rise
* Copy-proof with 4.3 billion possible codes (Random code generated)
* Quality Products at fantastic prices!
Standard Features:
* Converts your manual central locking into REMOTE CENTRAL LOCKING!
* Works on any car/vehicle - UNIVERSAL
* Two Anti-Code Grabbing Transmitters
* Space inside the remote for your own transponder (chip)! (i.e. If your existing key has chip inside, some can transfer their chip into our remotes! and save 100’s £££).
* Adjustable Shock Sensor:
* Parking Lights Relay Build-In: This system is build-in with a 20A relay for R/L two side turning indicators (Direction lights).
* Remote Control Arming/Disarming
* Remote Silent / Sound Arming/Disarming Mode
* Door closing failure/warning function
* Auto Reset:
* Automatic Alarm/no alarm.
* Remote Car Finder (car seeking)
* Panic Mode
* Remote Trunk release:
* Window Roll-up: This channel is a negative(-) output feature
* Emergency Override OR Lost/Not working REMOTES: If your transmitters are lost or not working or you are in Anti car jack mode at any time you can manually disarm your system!
* Central door lock relays build-in
* Status LED Identification:
* Door Trigger
* Parking Light Flasher
* Remote Door Lock/Unlock
* Ignition/Starter Disable
* Last Door Arming (Programmable)
* Auto Central Locking (Programmable)
* Remote Learning (Learn up to 4 Different Remote)
Package Contents:
* 2x TOP QUALITY Remote controls (fobs)
* 2x your own car logo on the remotes! - SEE below
* 2x FREE Blank Keys - Blank key can be removed!
* Control unit
* (Main brain Processor) Immobilizer Relay
* shock sensor - adjustable
* LED (light to see alarm is active)
* siren 6Tone (Makes 6 different attention grabbing sounds (cycles through all six, one after the other)
TO Hear the sound this siren makes click on this link: download an MP3 Siren_6_tone_Sound
* Wiring harness (with fuses)
* User manual
* Universal fitting instruction +PLUS Car Security Installation Guide
* vehicle-specific fitting instructions! (please specify at the time of your order; your car make/year/mode)
for most cars we can give you exact wiring diagram for your own car!
