Помогите найти схему LH-SFI, E-GAS, DI, SPS на m119. По Lhsfi висят две ошибки: "22"-O2S 1 heater, open/short circuit и "4" Voltage at hot wire MAF sensor (B2/2) insufficient or too high, or open circuit in ground wire at hot wire MAF sensor, отсутствует питание на лябде и дмрв. В eGAS "6" Starter lock-out/backup lamp switch (S16/1). SPS "4" Right rear axle vehicle speed signal malfunction, "7" Vehicle speed signal from transmission missing "8" Short circuit between speed sensitive power steering P-valve (Y10) (+) and UBATT "9" Speed-sensitive power steering P-valve (Y10), short circuit "10" Speed-sensitive power steering P-valve (Y10), open circuit "11" Voltage supply to speed-sensitive power steering control module (N49/1) insufficient voltage wdb1400501a051796
Пользователей:
36 от 22 01 24
Гостей:
5587 от 25 05 24
