Горить BAS/ESP
ricar_CDI
До 20-30км/час все нормально. Если бьистрее горить лампа BAS/ESP.
От диагностики - ошибка C1529. Модул ESP стоит очень много денег.
The traction controls and ABS, etc. systems are very complicated and problematic.
You can do as you choose by taking the advice of your mechanic, but you should try
a few things first before replacing the module.
1. Without your foot on the brake, start the truck. Are the lights on?
2. Now step on the brake. Are the lights on?
3. Move the truck a short distance. Do the lights come on?
4. While moving turn the wheel in both directions. Do the lights come on?
This is why I asked you to explain in detail.
While the truck is running turn the steering wheel all the way to one side
and then the other and see if the lights go out. A restart might be necessary.
If that doesn't work, try the more detailed procedure below.
Ето я взял из Benzworld, но я там не зарегистрирован.
Мой VIN WDB2021941F962499 :eek:
Get the attached pdf:
[attachment=0:29m069xh]ESP-BAS Lights Road Test.pdf[/attachment:29m069xh]
  • ESP-BAS Lights Road Test.pdf
    56,5 КБ · Просмотры: 247
ricar_CDI
Спасибо, Tir!
Електроньй модул (компютер ESP) у меня А202 54 54 732.
Можно менять на А 202 54 54 932?
Я знаю, что после етого надо перепрограмировать в дилерском сервизе. :eek:
Demon2023
