Проблема ABS и ASR
Начну новую тему и постараюсь конкретней объяснить свою проблему.
Завожу мотор, все лампочки тухнут. Как тол ко трогаюсь через метров 5 - 10 сразу загораются лампочки АБС и АСР.
Может вкину отчет от диагностики.
Control unit version
Name Value
Control unit name PSE
MB number 140 800 04 48
Supplier Bosch
Hardware status 15/90
Software status 30/91
Diagnosis identifier 00/02
Name Value
Control unit name ASR
MB number 010 545 28 32
Supplier Bosch
Hardware status 00/00
Software status 12/91
Diagnosis identifier 02/00
Fault codes
Fault code Description
03 FL vehicle speed sensor(L6/1).
Actual values
Name Value Unit
01 FL speed --- km/h
02 FR speed --- km/h
03 RL/RA speed --- km/h
04 RR speed --- km/h
05 Solenoid valve relay A7/3k1 tml 30 --- V
06 Lateral acceleration --- V
07 Pressure switch ---
Fault codes
03 FL vehicle speed sensor(L6/1). sxema ASR pdf
Quick Test
Name Value
LH1 F[2]
LH2 No fault code present.
DM (Diagntic Module) No fault code present.
EFP/TPM/ISC F[3]
GM F[4]
Traction (ABS/ASR/ETS/
ESP) No fault code present.
PML F[5]
RCL (DAS1/X) F[3]
PSE (Pneumatic System Equitpment) F[2]
ATA (Anti-Theft Alarm) F[2]
Air Conditioning No fault code present.
Name Value
Control unit name LH
MB number 014 545 18 32
Supplier Bosch
Hardware status 14/91
Software status 46/91
Diagnosis identifier 00/01
Displacement 5.0 L 8 cylinders, 4 valves/cylinder ///
Program status 41
Data status 42
Engine colde start
Name Value Unit
02 Coolant temperature 81 deg C
01 Engine speed 862 1/min ///
25 Start signal(tml 50) OFF
14 Post-start enrichment OFF
15 Idle speed recognition ON
24 Battery (tml 30) 14.1 V
Engine warm-up
Name Value Unit
39 Transm. mode Selector position P,N
13 Warm-up phase OFF
19 Air pump OFF
27 Intake air temperature 40.4 deg C
Dynamometer
Name Value Unit
01 Engine speed 881 1/min
06 Injection time 6.95 ms
07 Air mass hot wire 27.1 kg/h
08 Hot wire voltage 1.50 V
29 Altitude pressure 995 mbar
16 Full load recognition OFF
17 Acceleration enrichment OFF
Name Value
Control unit name EFP
MB number 140 545 71 32 //
Supplier VDO
Hardware status 09/92
Software status 17/92
Fault codes
Fault code Description C
048 Set valve potentio-meter,potentiometer monitoring M16/1r1. ///
1606
0049 nformation
Name Value
Control unit name PML
MB number 010 545 82 32 ////
Supplier Kostal
Hardware status 24/90
Software status 24/90
Diagnosis identifier 00/00
Fault codes
003 Left/center front axle speed sensor failure.
0010 gidroblok ABS
001E
000B
7420 memory
Name Value
MB number 140 800 04 48 ///
Supplier Bosch
Fault codes
Actual values
Name Value Unit
01 Lock 1 OFF
02 Lock 2 OFF
03 Trunk lid rotary tumbler switch OFF
04 CLS interior control Lock OFF
05 CLS interior control Unlock ON
Name Value
Control unit name ATA
MB number 140 820 17 26
Supplier Becker
Hardware status 32/91
Software status 07/90
Fault codes
Fault code Description Status
006 Alarm triggered by FL/FR doors S17/3,S17/4.
0074 codes...
Actual values
Name Value Unit
08 FL/FR door contact switch ---
09 RL/RR door contact switch ---
10 Trunk lamp switch ---
Name Value
Supplier Bosch
Fault codes
Fault codes
004 Right front axle vehicle speed sensor failure.
0010
001E
6174 ion
Name Value
Supplier Kostal
Actual values
Name Value Unit
01 Valve current 0 mA
02 Valve current 918 mA
Fault codes
11 Vehicle speed sensors implausible.
Name Value
Control unit name LH1
Supplier Bosch
Program status 41
Data status 42
Вот что я проделал:
1. Проверил все датчики АБС на сопротивление и с помощью осциллографа. ---- всё ок.
2. Подкинул другой комп. АБСа. ---- всё ок.
- Кнопка выключения АСР пока не горят лампочки включается, но желтый треугольник не загорается. Загорается тол ко диод на кнопке.
- Если дав газа задние колёса начинают буксовать, то руль начинает цежело крутится. Токое чувство, что отказывает гидроусилитель.
Может у кого нибудь будут какие соображения, буду весьма благодарен.
